1989-90 bayliner 2159 hardtop.
chevymaher
LOL I kinda passed over the untidy stuff myself. Right out of the viewfinders reach most of the time. Pandemonium.
sphelps
It’s all in the angle of your pics Micky ..
The behind the scene stuff can be hidden relatively easily ..
Well sometimes LOL! :photo:
89 resorter
I may have to try that no beer thing …. my problem is that my buddies do show up when I'm trying to work on the boat and take advantage of my stocked fridge but I don't get any help lol.
mickyryan
yeah last guy that helped me grabbed a beer from fridge in garage and its born on date was 2012 i think :) sadly he has never came back :")
kcassells
Yea contemplating the same thing.
89 resorter
Disclaimer …. I still plan on having beer for me (how else would I get anything done?)
sphelps
I’m a 2 or 3 a month kind of beer drinker .
other than that every once in a while my son makes a really good whisky sour .
kcassells
All good! Personally in regards to alcohol and drugs I respect everyones position.
Heck if it weren't for alcohol the Irish would have ruled the world.
zool
I will continue to indulge myself and I will continue doing my best in the good fight against and dry rot and rust. :D
oldrem
I could sit and drink a quart of liquor in an evening (not every night lol) when I was younger - doesn't have any appeal for me anymore. Now I'll have 2-3 ales a month.
CrazyFinn
Use a good camera, get a really short depth of field, keep the background mess out of focus...
89 resorter
Yeah KC …. still no pics. Lets see if Micky tries to divert our attention from pics again by talking bout beer LOL
kcassells
What RU kidding me? I thought he posted pics. Mick I like the dirty pics, no reason to clean um up. l:mad-new: :sleeping:
Timr71
I have a good recipe for that:
1. put two ice cubes in a tumbler
2. cover with whisky
3. forget everything else and just drink that! :)
mickyryan
ok so was holding off to get some pics of finished stuff but i willl explain what i have been doing
1 all gas lines ran including a gas tank drain i installed on the transom,
installed a water/winterizing drain on transom as well
still need to install the oil drain on transom but i did make a nice adapter out of brass pipe, i threaded one end to be same threads as oil pan :)
got the engine wired with a electric fuel pump and a low oil pressure switch to cut off fuel when oil pressure is low, also put a primer button on dash previously so if boat sits awhile i can press button and prime fuel system
finished wiring to the bow for the batteries and made the floor of battery area out of starboard and sealed it in
engine bay is fully wired except for i want to put single wire alternator 100 amp on and need to wire blower and bilge pump after it drys and is set"used 5200 to bed it down"
today i finished wiring on engine and trim pump and installed outdrive , replaced water pump on outdrive as well , fired engine up it cranked right up and ran flawlessly except the exhaust
Click image for larger version  Name:	20180830_200356.jpg Views:	2 Size:	86.2 KB ID:	10645736Click image for larger version  Name:	20180827_164214.jpg Views:	1 Size:	57.8 KB ID:	10645739Click image for larger version  Name:	20180830_200347.jpg Views:	1 Size:	68.4 KB ID:	10645740Click image for larger version  Name:	20180827_164156.jpg Views:	1 Size:	150.0 KB ID:	10645741Click image for larger version  Name:	20180830_200410.jpg Views:	1 Size:	83.8 KB ID:	10645742Click image for larger version  Name:	20180830_200414.jpg Views:	1 Size:	73.8 KB ID:	10645743Click image for larger version  Name:	20180830_200540.jpg Views:	1 Size:	76.8 KB ID:	10645744Click image for larger version  Name:	20180830_200442.jpg Views:	1 Size:	60.7 KB ID:	10645746Click image for larger version  Name:	20180830_200548.jpg Views:	1 Size:	152.0 KB ID:	10645747 riser felt hot, now i had checked the elbow and exhaust manifold all were like new, remember this guy had a exhaust flap stuck in his lower elbow so he had replaced a ton of parts trying to figure out problem:), anyways i took outdrive off ran hose revered to be sure no debris then i checked thermostat and guess what none there, hmm could be the problem:) so i ordered one and have plenty of stuff to finish before it gets here:)
oh yeah here is some pics , dont judge i know my area is a mess i been working 9pm to 4am on it and haven't cleaned up
