I have a 1989 90hp 3 cyl motor which workes fine, but making a little too much smoke after my taste. A researched and figured it could be because of too rich mixture. I then went out on the lake to adjust the idle screws (now I says screws, since I think there are 3????) Please confirm.
I ended up not really messing with them since I could not see any change, but might still have turned 1 or 2 of them slightly off the setting they were on before. It sounds fine, but would like to know the bench mark the idle adjustment screws should be at.
The 3 screws are all turned 2 full rounds counter clockwise from lightly seated. I believe by turning them all slightly clockwise, i lean the mixture, and the smoke should be less.
I know that running slightly rich is better than lean, but would like to turn the smoke down a bit. Let me know if there is a recommended setting to take aim at to at least start with.
Thanks
Thanks
