1989 bayliner 1950CX
bdanie
I got a 89 bayliner 1950Cx it has the 5.0 302 motor in it with the OMC cobra outdrive with 200HP im looking to get a new prop. I just bought the boat and the one on it is the orginal one and it works good but it has seen it's better days. I have no clue the size or pitch or really any info on the prop. Any ideas on a good prop for this boat? I'm not sure if i want to spend the money on a Stainless Steel one. I just know nothing about props
usskydvr
Re: 1989 bayliner 1950CX
So to start take your boat out with a normal load ( people, gas,gear, etc.) and fine out what the wide open throttle (WOT) RPM is. Then take a look at your prop hub for numbers like 14 1/4 x 19 or anything else. With that information a good recommendation can be made.
bdanie
Sounds good ill do that this weekend and get back to you...Thanks for the help
