1989 bayliner capri 2.3l fordengine-omc cobra gear case
eru
Re: 1989 bayliner capri 2.3l fordengine-omc cobra gear case
ok wait i see that the carburetors from cars overflow inside the intake, not outside to the floor, only motorcycles drain outside the carburetor,
soo some parts are the same from boats to cars ,,
well i bid on a omc factory repair manual its goint right now for $15.00 on ebay:D:eek:
a70eliminator
About the starter, I've been through the same comparisons, but did find two suttle differences, the brushes on the marine starter have a spark arresting shield around them, also the starter housing on the marine starter had the vents sealed off, you could convert one to the other easy enough but they are different, same with the carbs just suttle differences, slosh tube, vent, and probably more I don't know.
chiefalen
J1171 is stamped on all marine starters, alternators then it's marine.
No j1171 then it ain't marine period.
Might look the same but a insurance co. won't pay up if it sees no number.
You get pulled over on the water look to be towed in a your expense and big fines.
I already posted why the most important reason to go with marine parts you and your family's safety.
The carb gets piped back to the fuel pump. There is a yellow overflow hose, makes it a marine carb.
I tried explaining before in a reply, and i replied here with respect and understanding. But i can see you don't get it.
All said and done, do me a favor post the hull id, and where you boat so i can stay as far away from you on the water as possible.
I'm done here.
Gary H NC
i took a part the original boat starter
Ayuh,...
It's 20 Years Old,.....
Do you honestly believe it's the Original,..??
As stated by Capt. Jason,....
"Just because you Found it that way,... Doesn't mean it's Supposed to be that way"...
Don S
There are a LOT more to a marine carb, fuel pump, and electrical parts than chiefalen mentioned. You can't just stick a hose some place and call it good.
You also have a Private Message regarding your signature.
a70eliminator
[/QUOTE
Eru,
your not alone, there certainly are members here new to I/O engines and drives that have asked the same exact questions and the responses are always going to be the same when it comes to marine vs auto. Learn from it and continue on.
CheapboatKev
Eru..
My very first post here was that I bought an automotive starter for my straight 6 motor....
didn't want you to get the impression that you are alone in your line of thinking...I just wasn't as stubborn as you in persuing it, lol..
These guys will walk you through dang near anything you come across with your project. They know what they are talking about..
eru
ok... guys you wont im goin marine not car parts..:redface:
ok if i going to invest in the boat definitely aim going to follow you advice
now is had another problem is the exhaust manifull is leaking posible is crack:mad:
thats going to be expensive, but ill get it probably from boat wreckling ( junk yard for boats)
only one cuestion for now ...in order to get a sticker for the boat and a lic plates for the trailer do i need to take it to the coast guards for inspection?:confused: i now its dmv but i need to go coast guards?
td8
Here were I live there are no boat inspections you pay a fee and get your sticker that's it.As for auto parts I would say 90 percent of used boats have auto parts on them somewhere.
eru
first thing im ordering the shift cable($85.00 with gaskets) the bellows and the water pump $188.00 :eek:
the bilge blower is frozen, i found new one in ebay for 20.00:p
jayinpa68
Im sorry but I must agree with everyone. Ive only been on the water for a few years but one of the first things you do not do is cut corners especially when its a safety issue. take the advice evryone is trying to give you. Its worth it to have to spend a little more time or $ to make it safe
