Thomashair66
- Joined
- Jun 18, 2017
- 3
So first and foremost thank you all ahead of time. First time boat owner with a 92 proline 16' w - 89' dt85. I bought this thing without having water tested her, she starts up well, but put in water and she bogs down and dies when put in drive. I've checked compression 150,135,150, I've run through fuel lines, idle air screw mix is correct via manual etc. I have noticed many things taken off of engine like water cooling sensor,oil mix tank ( presumably converted properly ) mixing gas@ 50:1, I'm currently rebuilding carbs but 2 of three have been quite clean. I've looked through several hundred past posts looking for anything I'm missing but can't seem to find anything. Please help... I've replaced plus several times, she'll sit and idle and rev just fine outside of water but it's like she's allergic to water
. I will be measuring out the shift linkages as well when installing rebuilt carbs just to ensure that is correct as well. What am I missing folks, any help or direction is greatly appreciated.
