tallcanadian
- Joined
- Sep 7, 2006
- 3,250
Has anyone ever experienced this? What an ordeal. However from what I've researched, it isn't an uncommon issue. I haven't tried since to run it. I'm a little worried it may happen again. Dang thing was so hot. I did have it on muffs and was having problems getting it started so I put a bit of gas in each cylinder. Put the plugs back in and it started all right. Revved wide open it seemed. Turning off the key did nothing. I had to in hook the gas and let it run out or blow up, which ever came first.
What I did do after was check my grounds. Everything is okay. Checked the carbs again, butterflies were closed. Apparently even if you pull the plugs wires off it would have still ran like that.
So I guess I will put it in a barrel next time to see if this thing is still living.
