loose rivet
Thread starter- Joined
- Jul 31, 2011
- 151
I was given a boat this weekend with a rather clean looking 1989 Evinrude 50hp on it, the motor has two issues, the tilt piston is gone, broke off at the motor bracket side, and when I run it, the alarm in the controls sounds constantly after about 15 seconds.
It's not hot, when it goes off it don't have the chance to get hot. The motor was a VRO motor, but I was told that don't work and to run premix. I've been running it on 50:1 mix. The oil tank is still in the boat but the hose is cut off and plugged where it goes into the motor. The tank is full. The motor is still running a VRO pump. The last owner said they had the VRO disconnected after their other boat's motor seized up when it's VRO failed.
It runs fine, no noise, it don't overheat, and it pumps water fine. I tried disconnecting the overheat sensor at the motor and the alarm still sounds. If I disconnect the wire from the VRO pump, the alarm goes away.
The pump and all it's lines are still intact, they simply put a bolt and clamp on the line near the fuel line connector externally.
Could their running it this way done any harm? I can't imagine anyone running it for very long with that alarm sounding all the time either, so I doubt its been that way all that long.
