1989 Evinrude 88 SPL fuel line recirculation routing
drobertsobx
Does anyone have a fuel line routing Diagram for the 88 SPL it is pre-mix no VRO and does have the primer solenoid.
I have 5 hoses
[2] 6" still attached to the carbs
[2] 18"
[1] 15" that Tees's into [2] 6" hoses
7 nipples (Including the solenoid)
Intake has 4 check valves 2 below each carb. Oriented port and starboard (assuming for each cylinder)
2 bypass cover nipples
1 Primer nipple
1 of the 18" still had my marks and runs from cylinder 2 bypass cover to bottom starboard side (cylinder 3???) check valve, directly below the fuel pump.
all other marks rubbed off or were washed off by gas from the carbs.
The SELOC diagram shows hoses connected to all 4 bypass covers (wrong for this motor) and is impossible to distinguish between primer hoses and recirculation hoses.
This motor only has nipples on cylinder 1 and 2 bypass covers
Picture1 shows no nipple on Cylinder 4 bypass cover and cylinder 2 hose in place)
kcassells
LOL I saw this style diagram for my v6. Total wrong.
Glad I did not buy that manual.
