1989 for 125 pics needed.
trioval00
I picked up a Bayliner and It came with a Force 125 (1251x9d ) we have the motor all back together and there are a few brackets we can seem to pind a home for, the main one is the Nuetral switch. it's the one little black box with a yellow wire at both ends with a white button . does anyone have a few pics of a motor they can post so I can get an idea where and how they are installed...
Thanks
Mark
Frank Acampora
Re: 1989 for 125 pics needed.
Neutral interlock switch mounting bracket installs on the lower manifold cover on the diagonal. Bottom starboard bolt and next one up. Post a photo for you in a couple of minutes. First photo is of the control cable bracket which you also may need. It mounts to the bottom bypass cover.
trioval00
Frank, those pics did it,
Thank you................
Mark
