1989 force 125 no fire
roscoe
You have the blue coils, so you have the blue cd modules also, correct?
Seems unlikely that they both would go bad at the same time.
Don't have a number for the stator ohms, but they seem a little low.
If you have a dva peak voltmeter, check the stator output, should be 210volt.
Then check the trigger.
Disconnect violet, whit, brown, and white/black wire from the switchbox.
These are the wires for the trigger.
Check ohms between violet and white wires.
Check ohms between brown and wht/blk wires.
Both should read between 700-1000. If not, the trigger is bad.
I assume you have a repair manual if you did a rebuild.
Which one do you have?
