Glenn Iverson
Thread starter- Joined
- Aug 14, 2016
- 44
Just picked this up last week. Tried it out for first time & noticed engine rpm would barely get to 4000 WOT & top speed was 30mph trimmed out. (two people in boat)
Motor seemed to run good but a little rich. Noticed the prop was a 19 pitch. It was really slow out of the hole & towing a tube was almost boring for the kids.It seemed to work hard & after running some prop pitch tools I found out it was over propped. Swapped out the prop for a 15 pitch & ran a can of seafoam through it. Motor is much fasterr out of the hole & sounds a lot happier & tops out around 5000 rpm trimmed out at 26 mph. Specs for this motor call for 5000-5500 WOT. I can now tow a skier no prob but for some reason the top speed seems low to me even though everything else seems to have improved.I am aware that I gave up about 5 mph for better holeshot but still seems low. I have not linked & synced carbs yet nor adjusted timing. The Arriva is a big boat for this motor so just wanted to find out if these readings are actually out of whack before I start to tinker. Boat is in good shape with new floor & upholstery & cant see any obvious signs of rot or foam saturation to weigh it down.
