1989 force 125 tilt trim
my55
on my force the tilt trim raises the motor but it falls back down right away .<br />whats the problem<br />it dont look like any leaks but when you take out the side screw on the pump it leaks air from there is this right?<br />the hole is also striped ...would this cause it?<br />and how do you blead it and what kind of fluid goes in it.and how do you put it in <br />thanks again <br />mike warford
scubakidz
Re: 1989 force 125 tilt trim
I have the same problem down to the fill screw keeps turning and not getting any tighter on my 1990 120 force, If you ever get the answer please E-mail me At scubakidz@aol as to what type of fluid i heard 10w 30 but i havent tried it yet perhaps some one here can confirm, good luck
scubakidz
has anyone out there experienced this problem besides us two any help would be great
clanton
ATF will work fine, fill thru screw hole on side of pump, pump is self bleeding , repair striped threads by installing elbow with pipe threads and pipe plug.Replace pilot valve seal, pn 820719, will stop leak down. Remove piolt valve by removing allen screw from side of pump,pry off end of valve that has hole in center, inside is valve needle , seal on end of needle.
scubakidz
clanton thanks for the tip were can i buy that valve i have the clymer force manual but it does not show how to install the valve, can i take that valve out and not leak the fluid out or will it all poor out, when i rmove allen plug, please e mail me scubakidz@aol i would like to discuss this further thanks in advance.
clanton
You can get seal at Force/Merc dealer. Fluid will drain when you remove valve, No instruction in manual because, parts for hyd pump not serveiced. Remove valve call me at 352-746-1953 after 7 PM EST, I can tell you how to get to the seal, or e-mail me photo of valve Clanton@atlantic.net.
