mikesdad
Thread starter- Joined
- Sep 19, 2010
- 27
Have '89 Force 125 that has been giving me an education in the month that I've owned it.
Replaced the impeller and rebuilt the upper carb last week and took it to the lake yesterday and somehow managed to lose 3 mph on top end.
I'll back up a bit and say that at times this thing cranks over like the battery is going dead ( which I knew it wasn't ) so I was thinking that I had some timing issues to deal with next.
Didn't know much about rebuilding carbs, and nothing about changing impellers on outboards, but with my shop manual and searching around this site and reading and doing, I'm getting a 'hands on' education.
I took the cover off at the lake yesterday and was staring at the carbs. wondering how I could have LOST power after replacing a bad needle valve when I happened to look up and see that the arm on the trigger, is broken. I would have to guess that the timing has therefore been set by whatever wave we happened across.(or the previous owner since it looks like it has been broke and has tried to be 'rigged' back together for a very long time)
That would probably explain why sometimes it would start easy and sometimes it wouldn't, and sometimes it felt like it was loading up at lower speeds and why at times it was a bear to get to idle or to go from idle to putting it into gear---STALL.
I wire tied it back together temporarily yesterday and got my 3 mph back ( still had the other symptoms though which is understandable since the timing is undoubtedly way off) and was thinking that all I had to do was order me a new plastic arm to attach to the linkage.
WRONG.
Today I learned what a 'trigger' is and I also learned that the broken piece is part of that trigger that costs between 2 and 4 hundred bucks.
Not gonna happen as I am just about ready to rip that motor out by the roots and replace it with a Make that is still in production and trying to find parts for is like looking for a needle in a haystack.
So, if you've made it this far, here are my questions:
Although I have the shop manual, does anyone have any tips as per removing the flywheel?
From what I read on-line, I want to be real careful not to damage the stator ( another thing I've learned as to what it is, and what it does!) if I have to take it off to take the trigger off to fix it.
And, and ideas as to what material to make the replacement arm out of?
Thanks for the replies.
WRONG.
