1989 Force 35- Help with info....Tach Help, Impeller help, Fuel filter Help
camawelander
Thanks for all of the help so far, and ....
I have a few more questions...
I have spent an hour in this forum looking for this info and I just can not find it.
1. What are the specifications for a tachometer that will work on this motor?
1989 Force 35
Serial # 1012
Model #357y9a
2. Also which impeller is the proper replacement for this motor? My Seloc and Clymer manuals are confusing me.....(where can I get a real manual for this specific motor)
3. What type of fuel filter does this motor use..(I see a little black plastic elbow type of fitting that says Fuel Filter on it - is this the filter or is it back in behind there)
Thanks so much for the time!!
eurolarva
Re: 1989 Force 35- Help with info....Tach Help, Impeller help, Fuel filter Help
Impeller Quick silver part number 47-F433065-2 costs $15. Chances are that motor did not come with a fuel filter. You can find an inline filter at NAPA or at an outboard motor place. For the tach look up tiny tach on the internet and give them your motor specs and they should be able to fix you up.
