1989 Force 35 - Model 357Y94 Serial 1012 - Tachometer Install Question
camawelander
Hello,
So, my TinyTach just died and I'm thinking about installing a Teleflex or similar style in dash tach.
The motor is the 1989 Force 35 - Model 357Y94 Serial 1012.
Attached is a photo of the "electrical connection strip" on my motor with the corresponding sticker that describes where each terminal goes.
It looks like there is a terminal ready for a tachometer install...purple wire.
Is the install as easy as running a wire from the back of the tach to this terminal?
And also probably run a ground wire?
Will I need to run a separate power wire, or will the tach terminal power it?
Also, any recommendations on style or type or brand that I should look at?
Is there a specific type of tach I need.
Thanks!
jerryjerry05
The wiring harness should have an extra lead or the purple lead taped back?
​The harness is one they used for a lot of motors and should have an extra lead.
The tach you'll need is a 20 pole tach.
camawelander
Thanks for the help! It looks like there are a few leads taped back up under the console...Perfect!
The research I have found so far is saying that I need a 12 pole tach....several different sources, specifically the
"Faria 32805 Euro 7000 rpm"
Installation Instructions PDF I found on-line. This is the model I'm looking at purchasing, and it lists the 1989 Force 35 as needing a 12 Pole Tach.
I am inclined to trust your information and experience with these motors, but I want to be sure before I order.
Why do you say I need a 20 pole?
Thanks again for the help!!!!
