bama.hunter
Thread starter- Joined
- May 23, 2011
- 18
I have a 1989 Force 50hp that I've been messing around with for a couple of months now. I've finally got it idling, cooling, and had used it 3 or 4 times with minor issues until last week. While cruising at full throttle, which is about 25-27 mph the engine suddenly slowed down to about 5-10 mph. There was no noise or anything just dropped off and wouldn't pick back up speed. Engine will shift in and out of F / N / R fine with no issues. So I thought it might be the hub on the prop due to it being the original prop. After taking a test run today with a new prop/hub its still doing the same thing. I can go forward but only at about 5-10 mph, but no more.
One issue it was having was at full throttle it would surge some and if I backed the throttle off a little it would stop and I could proceed back to full throttle again. I don't know if this had anything to do with the problem.
I'm thinking the problem has to in the foot or the throttle cables though and I'm lost on where to start.
Any ideas on what might be the issue.
Thanks, Jay
Thanks, Jay
