1989 Force 50hp ... Which is 'number one' cylinder?
madhtr
... top or bottom?
I'm doing some ignition work on this motor and I need to make sure that the coil plug wires are connected to the proper cylinders
Thanks! :)
madhtr
Re: 1989 Force 50hp ... Which is 'number one' cylinder?
K, found it:
number one cylinder is the cylinder closest to the flywheel.
hopefully this will help someone else, cheers :)
roscoe
Yes, numbered from top down starting with #1.
