Jared Dickerson
- Joined
- Jul 28, 2020
- 3
856X9F Chrysler/Force Outboard
Last trip out in 2021 before the boat went into storage I started having problems. Starter comes up and Engages Flywheel, makes around 1 rotation then drops out of contact. Starter continues to turn after it disengages. I don't think the motor is firing before it disengages as I'm not hearing a pop or seeing any exhaust. New starter is on it's way as I intended to replace it before I started having problems. Looking for other things to trouble shoot before I pull it out for the summer.
Note: as an experiment I held the starter in contact with the flywheel with a pair of pliers, after 2 rotations it started and continued to run normally. The disengagement problem happened after the engine was hot as well.
