bearcave86
Thread starter- Joined
- May 26, 2015
- 28
Hey guys I just bought a 1989 Cajun bass boat with a 1989 Force 85 HP engine. I can't find a serial number anywhere on the engine or transom and I need to order a thermostat and a new impeller. It seems there are several different engine variations and I don't want to order the wrong part. So far I have replaced the fuel lines, primer bulb, fuel filter, added a second fuel filter, drained old gas and added new gas, cleaned spark plugs and disassembled and cleaned carbs (filthy). I was able to get the engine started today and ran it for few seconds. I took out the thermostat to make sure it would open and it would not so I need a new one. I plan on changing the lower unit oil and thats really all i can think of to change. I also have a leak somewhere on the trim and tilt the engine slowly lowers after I raise it. So if anyone can point me in the right direction on the thermostat, impeller and trim/tilt rebuild kit I would very much appreciate it.
