1989? Force outboard model #H0853F89G
swfladad
ok first off i apologize for my comment about not getting help on my motor id question earlier.i was in a pinch for time.but now I need to know how to remove the plate that is under where the impeller housing is mounted on. I removed the 4 bolts that hold it on but it will not budge. also when I tried to pry it off(very gently) I did notice that there is no gasket there. should there be? the previous owner had this off i belive because there is some blue gasket sealer around it. I was wanting to remove this plate to see if there was any pieces of the old impeller in there because I am changing the impeller because it was in pieces.If I can't get this off easily could I just replace the bolts or will there be a leak? please help me as I do not have a manual and I can't buy one just yet.or if there is a free manual online?
jerryjerry05
Re: 1989? Force outboard model #H0853F89G
Usually the pieces go UP the water tube.Not down.Can you post a pic?J
