1989 force125
roofer11
has spark,but starts some of the time.shop says may have to replace entire electrical system.$3000.00 bill.does anyone have a similar situation or answer,thanks
Surlaw
Re: 1989 force125
I have an 89 125 hp force myself. You can replace all the electrical yourself for much less that that. Might be another problem for not starting all time. If it does start than I'd say electrical does work. Getting a repair book will help a lot. You can check compression pretty easily and if you have timing light check if spark is getting to all the plugs. You can switch coils around yourself to determine if one is bad. Could be bad gas too or not getting enough gas or too much. I had one spark not firing on mine and switch coils around and got no difference. I than replaced the power pack with another one I had as spare and that solved the problem. One power pack controls #1 & 2 cylinders and other power pack controls #3 & 4 cylinders. The repair manual will help a lot. Good luck
Surlaw
Re: 1989 force125
Oh yeah forgot to mention. For $3000 you can buy a few other motors. I'd say the shop is pretty busy now but for $3000 you'll go to front of the line.
john from md
Re: 1989 force125
We need more details. What exactly is it doing? What maintenance have you done to it. We are not mind readers.
roscoe
Re: 1989 force125
If you have good spark, then there is no reason to replace anything electrical.
Well, possibly the rectifier if the motor doesn't charge the battery.
Find a new mechanic that knows how to troubleshoot and diagnose.
jerryjerry05
Re: 1989 force125
Sounds like he doesn't really want to work on it and wants to just replace everything to be sure.It probably won't run then either.
At #3000 he's screwin you!!!
Fill out the profile and like John says tell us what it's doing.
Oh yea I'll do it for $2500.J
