1989 force85 flywheel magnet
393Clevor
who here has re glued the magnet back in? does it matter where the slice is?
393Clevor
is there any special way it needs to go back in.. ?
Nordin
I have done it and there was "marks2 from the old glue in the flywheel.
I just glued it back refer to the old "marks" with epoxi 2 component glue.
jerryjerry05
The splice? anywhere is ok.
The important thing is the old glue must be removed completely.
On the magnet too.
Don't use a glue that swells(Gorilla Glue).
393Clevor
On the magnet too.
Ya I used a belt sander and cleaned off all the old glue (kinda looked like two sided tape) off the outer side of the magnet and then used some sand paper rolls on the flywheel... Then cleaned everything with Acetone and used JB-weld to glue it back on..
