SparkieBoat
Thread starter- Joined
- Aug 17, 2009
- 3,643
The reason I am removing the flywheel is to check the magnets/timer base. I have replaced the regulator (CDI), then the motor ran fine for a while, then one side of my power pack quit, after getting proper DVA voltage from the brown stator wires I purchased a new CDI power pack, after installing the new pp I now have no fire at all on either side, I have disconnected both kill wires at pp, disconnected the yellow wires, still no spark.. and have 20 DVA on the orange wires. The black/white wire going to the timer base on the 2nd connector has 8V. I have done every test listed in the CDI troubleshooting guide, and the white wire to the purple, blue and green wires shows nothing. I just want a way to make positively sure it is my timer base before ordering a $300 new one.
My stator does have some leakage, I believe it was a result of the old regulator, but it test out perfectly 180-200 DVA on both brown wire sets.
any ideas on how to be sure???? Thanks
