northwoodslivin
Thread starter- Joined
- Feb 3, 2010
- 323
hey guys,
figured I would make a new thread as my old one was way to large to follow things.
Ok I have a problem. I have this sneeze on idle, I cleaned the carb and all seemed well, got out on the lake after letting it sit a few weeks and it is doing the same thing, took the carb off and cleaned it last night, also installed this fuel filter that is to be used with carbed outboards. When I start the motor it will run "still sneezes" and now I am thinking my fuel pump is shot, the fuel filter will empty out, and I have to press the bulb to fill it back up or else the motor will run it's self out of gas. My father seems to think the fuel filter is to small, I dont think so as this filter can also be used for automotive use on carbed motors as well, so I think the flow of the filter should be more then enough. I took the fuel filter apart and inspected for any dirt, nothing. However I am noticing little tiny black particles in the filter it's self.. I am stumped and ready to sell the darn thing.
When I had it out on the lake last it will run fine at WOT, but often kick and cough leaving a big plume of smoke rising out of the water when it does so. I suspect my low speed jet is again plugged, must have been some junk in the fuel line to the carb, or maybe my fuel lines are getting old, but they look good on the outside.
Thoughts?
Thoughts?
