1989 johnson 8hp stop button?
Bob427
other than pulling the lanyard kill switch on the tillier
is there any other stop button on the engine?
Thanks Bob
Vic.S
Re: 1989 johnson 8hp stop button?
That is the stop switch. Can you not press the centre of it to stop the engine with the lanyard still in position ?
(Also, if its like earlier models, the knob it is mounted in turns to adjust the idle speed)
raczekp1
push out the chocke button will kill the engin
Vic.S
It would be more sensible to pull the safety lanyard off rather choke it to death. There's no objection to doing that but I am pretty sure you can still press the stop button with the lanyard in place.
Tim Frank
I have the E/rude version, and the lanyard/clip is an emergency feature. In normal use you can simply push on the red knob at the end of the tiller to stop the motor...as Vic suggests.
Bob427
you guys are correct push in the red button on the tiller where the lanyard attaches
thanks Bob
