1989 Johnson J150STLCEM Flywheel
gbrowning
I have a 1989 Johnson 150 (J150STLCEM) with no spark.
flywheel appears to be bad. P/N is 583844 but I cannot find one.
Does anyone know if this is a 9 amp or 35 amp system, and if there is a replacement flywheel with a different p/N I can use ?
wilde1j
Re: 1989 Johnson J150STLCEM Flywheel
Why do you think it's bad? Magnets, the only active part, are replaceable if broken or missing.
Faztbullet
Cant really go by that chart it is not correct on the V-6 crossflow(ask TD) you magnet locations for that flywheel are: with keyway @12 ths magent slit will be @ 6 and 11
