whopperstopper
- Joined
- Jun 21, 2004
- 13
I pump up the primer bulb and can see gas in the gas filter but it drains back to the tank in a few seconds. As long as I pump the bulb, the engine will run. <br /><br />There are no gas leaks anywhere. I have not replaced the end fitting on the hose but it does not leak. The primer ball is new (Mercury brand) as is the gas line. <br /><br />I removed the VRO tank and have oil in the gas tank.(new gas tank) The oil line to the fuel pump is not plugged but it does not run any better when I hold my finger over the hole. Gas still runs out of the filter(on the motor)just as fast.<br /><br />What am I missing? Do I need a new fuel pump?<br /><br />Engine has 14 hours. Hasn't been in the water since 1990. I've re-built Carbs, changed water pump impellor, and changed oil in foot.
