1989 Mercruiser 3.0 L, Mercarb, DDIS..bogs, no power
fat fanny
Re: 1989 Mercruiser 3.0 L, Mercarb, DDIS..bogs, no power
I have gone through this a couple of times on my 3.0lx and the symptoms you describe are dead on but do your comp, test a couple of times and make sure the rig is cold. if the #'s don't change pull the head and look at the gasket very good and breaks between cylinders carbon burns but after removing the valve cover rotate the engine to make sure all of your valve train components are operable. It is a posibility the gasket could be shot but the #'s on #1 &#4 are odd ususally it's adjacent cylinders but who knows when everything has been dissasembled take a good straight edge and lay it on the deck of the block and use a feeler gauge you shouldn't be able to get anymore than a few thousands under the straight edge do this in numerous places especially between cylinders and the outer edges do the same with the head after a good cleaning of course. This is not wasted effort the head will have to come off anyway. post back with some results all this info is in the Merc service manual. Oh yea another trouble shooting tip for symptoms such as this is a spun prop hub.
beads8
Well I finally got time to pull the head and it was very obvious what the problem was. Cylinder 1 & 4 had bad exhaust valves. Burnt, deteriorated etc. Head gasket had an obvious leak between 2&3 Cylinders. I had to order the Valves as I couldn't find them in stock. I tried to match a car engine but Autozone and Advance didn't have anything in stock anyway. Should be back up and running by next weekend, now that summer is almost over :(. Oh well. God willing I'll be able to enjoy it fully next summer.
beads8
Yay....she's back. Replaced the 2 burned valves, re-seated the others, and she runs like a champ..."like the old days" as my kids said when coming in from tubing. Thanks for all the advice through out the process. I'm sure I'll see ya'll in the futre.
