This may be a two part question but not sure. I have noticed a small leak from the back, at the transom/motor seal. The transom does feel a little soft in some spots so from reading appears that this would be the problem. I began taking off the outdrive yesterday, and there was a milky sludge in the u-joint bellows that did not appear to have much water considering it was in the water only an hour before. Could these be related or do i have one problem with a transom leak and another keeping gear oil out of the u-joint? Thanks for any advice, this boat/motor sat in the water for a long time and was seized when i got it
