gschultz05
Thread starter- Joined
- Aug 15, 2010
- 24
good evening i have a 1989 20' cheetah limited surface tunnel boat with a 150 merc black max xr4, compression is 140 across the board, we had just got this boat about 2 weeks ago, boat runs great on the hose but previously under load it would collapse the primer bulb, since fixed. Boat has had the oil alarm go off since we have had it, the replaced the oil tank cause the connection was leaking on the cap, put good crimp clamps on all the lines on the engine since they had a small leak before, purged the emergency tank so its topped off. The alarm will sound once the motor gets to about 4200 rpm or above, if kept below that its stays quite and can just put around. looking for idea on what it could be? another thing is the boat will barely rev to around 5k rpm maybe a little more, we had an 87 black max before and that thing like to go. Not sure if this one is over propped or what but it dont go like it should.
