F-16 Falcon
Thread starter- Joined
- Apr 27, 2011
- 27
Hi folks, Here?s my very first post. I am helping my son out by getting his outboard running. It died running down the river and wouldn't restart. It's also been sitting for about 1 1/2 years now due to war (he?s military) and the distance between us. Anyway, I now have the boat at my house so I'm just now getting started on it. Here's what I've figured out so far. I verified there is spark going to both plugs. Today I plan to pull the plugs and see if they are gapped correctly and also check compression. What is the correct gap for the spark plugs on this motor? If compression checks out ok then I want to ring out what is presumably an on/off switch on the side of the motor? And then determine if also has an emergency kill circuit, and if so, where its located? This is partly why I need to see the electrical schematic. If someone can provide it I would most certainly appreciate it. Thank you very much in advance!
