1989 Mercury Blackmax 150 no spark
Boogracing
Re: 1989 Mercury Blackmax 150 no spark
Have you tried disconnecting the black/yellow wire on both switch boxes?
I'm having same issue here with a 88 mercury xr4 black max 150hp. All of a sudden have lost spark, if I disconnect these 2 wires and get spark back can I leave them undone? Thank you.
Dave1027
No. If you do that you won't be able to turn the motor off from the key. You would need to troubleshoot to find out why the black/yellow wire is being grounded.
Boogracing
Thank you for the reply. By removing the wires I got spark to starboard bank now, but none to the port side?
Dave1027
Those V6 motors have two switchboxes. One for each bank. Did you disconnect the kill wire from both switchboxes?
Boogracing
I did remove each kill wire. Got spark back to starboard bank none in port. I took wires from stator and swapped the fire followed. Now spark on port side none to starboard. Leading me to believe stator is good but a bad switch box?
Dave1027
If you swamped the wires coming from the stator (not the trigger), and the problem moved to the other bank, that would indicate a problem with the stator. Sounds like one of the outputs to the switchboxes is not supplying power. It's not the switchboxes because those are still attached to the same bank's ignition coils. They haven't moved.
Boogracing
Thank you for the replies and help. This is my 1st real outboard motor and bass boat. I moved the blue amd red wires from stator and swapped them to the other switch. Just got someone here amd fire stayed on same bank. So switch seems to be working and now looking like a stator issue.
