1989 Mercury Classic 50 Plug Wire ?
Karter25
I was in the process of changing my plug wires when I changed the plugs on my 89 45hp. On the coil end, the wire is VERT tight and doesn't want to come off. They do just pull off like the plug end and every other plug wire I have done? I am a novice boat owner but have plenty of experience on cars. Thanks
?----Why are you changing plug wires ?-----What is your motor doing / not doing ?-----Some plug wires are threaded into the coil.
Karter25
They look to be very old. Just trying to be proactive. Engine runs fine. I saw some older motors that had a distributer cap that screwed in. This wire has a boot to each coil just like a car wire going on a cap. I tried to load a pic but the site wouldn't let me.
merc850
The distributor models had the wires screwed into the cap but the coil end was pushed into it and had a clip for extra security.
If the wire has a rubber boot on the coil pull it off first, check the end and look for a brass clip, then use pliers to lever the wire out. WD40 can help make the boot move.
They can be very tight.
Karter25
Thanks. Is the brass clip part of the coil? Do they reinstall or come with the new wires? Sorry for all the questions, I looked all over Youtube and the web for these answers.
merc850
It's crimped on to the wire and should come out with it. Don't know if a new wire comes with one.
Karter25
Thank you so much. I finally found a plug wire picture that showed the brass clip. I was shocked at the price of these new plug wires. I am glad there are only 4 to buy.
Karter25
I would not replace them.
I am leaning that way. I just try to be proactive with all of my toys. I am not sure how often boat wires should be replaced. If I had a car that age, I would replace wires. Thanks for the suggestion.
