I’m having an overheating issue I can’t seem to resolve. It started after I lost an impeller in the sea water pump.
i replaced the impeller, stainless plate and the pump body sleeve. I removed the drive so I could use a large bottle brush to go through the gimble housing to the oil cooler, removed the oil cooler and used small bottle brushes to clean it out and I ran the large bottle brush through the hoses before and after. I got what I think is most of the impeller debris.
It‘s all back together and when I start it with the water supply disconnected at the thermostat housing and running the engine on a drive muff, the water coming out of the hose rises about 1-2” out of the end of the hose. Less than the manual says it should be.
Did I miss something?
