rhillman75
Thread starter- Joined
- Jul 28, 2010
- 176
I have a 1989 Regal Ambassador 233xl with a 5.7 Mercruiser with a Rochester Quadrajet. Full rebuild was finished 1 year with phenomenal results. My biggest issue and the cause of scratching my head is that sometimes when starting whether cold or warm, it either starts right up or I have to crank it 2 or 3 times and let it crank for up to 2 seconds. When it sits at the dock for upwards of a week, sometimes I can return to it and it will start right up without pumping the throttle. Same scenario another week later and it requires up to 2 to 3 pumps before it will start. The only issues when the engines is warm are at times I need to pump the throttle or crank 2 to 3 times. Some have told me to pump it no matter if the engine is warm or cold. I have had 3 rebuilders re-check each others work and all specs are within tolerance and it has a new float. They have offered a refund, but a refund won't solve the issue. Does anyone have this style of carb and if so, what characteristics have you seen from yours? The idle mix screws are at 2 turns out from seat position and the idle screw is 2 turns in from throttle lever contact. These are the 2 settings that the carb was at prior to rebuild. Thoughts???
