1989 Regal 4.3l v6 Merc questions!
Re: 1989 Regal 4.3l v6 Merc questions!
called the previous owner and said he had it running and water flowing correctly a couple weeks ago.. Not sure how the impeller would just go out but I guess i need to check it anyway.
Gear Housing Seal Kit for Mercruiser - Sierra 18-8370 - iboats
That the correct part for impeller rebuild?
Ok motor is alive and purrrssss quite nicely!
Ayuh,.... Ya Smoked the impeller, runnin' it Dry....
That appears to be the Right kit, yes...
thumpar
Test it with the engine running at the input tube.
MarkSee
Ha live and learn I guess. I had no idea that is what would burn up
Assuming you have a stock exhaust setup, the exhaust shutters/flappers are also likely to burn up without water flowing through the exhaust system.
Mark
achris
More fish than mountain goat
That kit is the right one if you are re-sealing the entire gear housing. If you're just doing the water pump, try this one.
Running without water will also have burnt up the water pocket cover.... Have a read of THIS. And don't for a moment think you got away without doing the damage... It's done, now it's up to you to fix it.
Chris.....
sptjet90Reflexx
Ok went to a mercruiser service center and picked up the impeller kit, and shifter cable kit. Went outside to pull the whole outdrive and it cracks loose but how in the heck does this thing pull off? Does the outdrive HAVE to be centered? Mines alittle left cause my steering is stuck for some reason. Anyone have a clue on that? no matter how hard you turn the wheel that thing will not move.
MarkSee
You did put the shifter in full forward gear right and can see that the shift shaft and shift shoe are pointing directly fore and aft?
Having it straight would be best.
Bouncing it up and down won't free it up?
Mark
sptjet90Reflexx
just watched another video, and it said that if its not in forward that it wont slide off. OK well mine isnt shifting which is why I bought the cable. Can I use a pair of pliers to shift it manually?
sptjet90Reflexx
Mark
Didnt see this post before I jsut posted again.. Yea shift cable is stuck.
sptjet90Reflexx
Mark
Its about 1/2 way out as far as on the bolts. Pretty sure its the shift cable hold me up. I just dont wanna slap some pliers on it until I get the OK from you guys.
thumpar
There was one time that I forgot to shift into forward before removing my drive and I didn't even notice until I went to put it back on. If it is out about 1/2 way I doubt the shift linkage is even engaged still.
achris
If you can't move it into forward gear you need to remove the lower housing first. That will allow the intermediate shift shaft to drop down a little and dis-engage from the upper shift shaft and allow you to then pull the upper housing off.
Chris.....
sptjet90Reflexx
Chris.....
Lower unit won't separate. I tried that first lol
Ayuh,... Ya might be able to shift it, from up-under,...
The shoe, 'n foot are there, just Look to see if they're straight, fore, 'n aft....
achris
You are going to have to separate it to change the water pump, and it's going to be a lot easier with it still attached to the gimbal housing. You have got ALL the bolts out, yes? 1 up front, 2 in the middle (ish), 2 under the cav plate, and 1 under the trim tab.... Should just fall off after that.... (and it doesn't matter what gear it's in)....
Chris.....
sptjet90Reflexx
These little silver plates with a single Phillips screw. Do I need to remove those?
sptjet90Reflexx
Also there is this like place on the upper drive that appears to be a hoist location? Is that what it is?
Ayuh,... It's only 'bout 80 lbs..... No hoist necessary...
'ell, adjust the trailer jack, 'n it'll balance, 'n roll off, or on, on it's skeg...
sptjet90Reflexx
Yea ill disconnect the steering behind the motor and get it straight, also try and manually shift it.
Got it moved into the garage so gonna be a lot easier to work on now.
