- Joined
- Jul 23, 2011
- 53,458
Do the diagnostic work before throwing parts at it
Any suggestions?Do the diagnostic work before throwing parts at it
No.When it’s idling it seems to be fine. Get it up to about 3000 rpm’s, the has a slight skip.
When I turn the engine off, the fuel drains out of the fuel filter within a few seconds. Is that normal?
It’s brand new K&N clear filter so I can see what the gas is doingNo.
What kind of filter?
That is against regulations and illegal in a bilgeIt’s brand new K&N clear filter so I can see what the gas is doing
Seriously? Why?That is against regulations and illegal in a bilge
It’s on the top of the engine, outboardOnly metal filters allowed. If the filter breaks, you explode
If there is a fire, the filter goes first and you explode
I don't remember that happening on my motor. I don't think fuel should be able to go backwards to the fuel tank (or wherever it's going, into the crankcase?). I'd be looking at the fuel pump or the primer bulb.When it’s idling it seems to be fine. Get it up to about 3000 rpm’s, the has a slight skip.
No. How do you shut off the fuel flow when the engine quits.Thoughts on an electronic fuel pump?
