1989 sea-ray cuddy cabin 7.4 Mercruiser whats the best prop?
jlangkil
I just got a 1989 Sea-ray cuddy cabin it was a gift it has a bent prop and I need to replace what is the best and worst prop to use its got plenty of horse power under the hood its got the 7.4 Mercruiser
kelleyja
Re: 1989 sea-ray cuddy cabin 7.4 Mercruiser whats the best prop?
probably need to know how big your boat is......Sea Ray makes a lot of models
jestor68
The NADA data base shows the smallest 1989 Sea Ray with a 454 motor is the 250 Sundancer(25 ft).
If you take the prop off, you should able to see the size stamped on the prop hub.
tazrig
Go big or go home! :lol:
its a sea ray 230 cuddy cabin
Ayuh,... Welcome Aboard,.... Take the bent prop off, 'n find the numbers/ size that's stamped on it,...
Without a baseline to start with, there's No answer to yer question,...
