1989 suzuki 85dt throttle linkage
waffles1
Re: 1988 suzuki 85dt throttle linkage
I looked again and found the throttle sensor. Do you think I should replace this even though my motor seems to be running better? Do you think the miss at low speeds could be to a wrong linkage or bad sensor? all help is appreciated.
Thanks,
waffles1
waffles1
Re: 1989 suzuki 85dt throttle linkage
I did not notice any less oil being used per tank of gas. Is this still a concern I should look into?
Thanks,
waffles1
waffles1
I'm finally getting a chance to check this out. anyone with any last suggestions?
