1989 Wellcraft 5.7L Was running......NOT NOW HELP GUYS
NHGuy
Re: 1989 Wellcraft 5.7L Was running......NOT NOW HELP GUYS
Yup 8 degrees btdc.
howe719
Ok guys I will adjust to 8 btdc AT idle.
Thanks again
howe719
anyone have an idea what that pink with blue tracer wire is for???? I tried to find some wiring diagrams but nothing I find helps.
achris
More fish than mountain goat
Ok... Just joined this thread, and I see a few things I think I can comment on.
1. First video. That engine sounded very much like it has a couple of stuck valves. Given that it sat over winter, I wouldn't be at all surprised. That would also explain the back-fire through the carb.
2. You turned the engine over until you had #1 at TDC, then found the rotor pointing at #6. To me, if you haven't moved the distributor since the engine last ran, your on the TDC firing stroke of #6, and the TDC exhaust stroke of #1... I wouldn't be moving that distributor anywhere....
3. The Tan/blue wire is the alarm system. It will have power on it when you turn the key ON. It should be connected to a switch (oil pressure, water temperature or gear oil monitor bottle) which will ground the wire (and fire the alarm) when a fault condition occurs. DO NOT connect it to any post on the distributor... It's the correct wiring for one of the distributor posts to have one wire (wht/red) and the other to have 2 wires (both wht/grn)....
Chris.......
howe719
Ok......... Little upset. Took it out on the water today for a test run. Started up. Pull out from dock and when I opened it up full throttle. Very very slow. NO power. Could not even get up on plane. So I just went back to the dock at pretty much idle speed.
I am thinking again carb or timing. No sure. HELP. Could I have it timed wrong? I put 1 at TDc and then made sure the distributor was hitting the 1 plug. Then I timed it to 8 btdc. That is correct right? Thanks
achris
Check plug wires and make sure they are on the right plugs. Then check them again.
howe719
I checked the plug wires three times. Still same problem. What else?
flipbro
I once had a 898 (305) that had back firing through the carb and no power tried many things tune up timing ect turned out it was a couple lobes on the cam were rounded. I replaced the cam set the lash and all was good run it 4 another couple years Just a thought!
howe719
Ok so I know the problem. Did a compression test and cylinder 1 , 185. 3, 185. 5, 185 and 7, 179. Odds good
Even. 2, 0 4, 0. 6, 25, and 8, 0 psi
My left even side is getting pulled tomorrow when I get home and will send away for test.
Report back once back on
Thanks
dingdongs
sounds as if the valves had seized in the valve stems and possibly on cranking the engine may now have a set of bent valves.undo all rockers and all the valve tops should be level as the cam will not be depressing them via the rockers once removed.
howe719
removed the head. everything looks to be pretty good. I am taking the head to the machine shop tomorrow. will report back the findings.
howe719
head was in good shape. the valves were ok as well but I had them replace them anyway. I put the head back on and re set ALL the rocker arms. That was the problem from the start. I had the Valves TOO TIGHT. after I did the first head gasket replacement last year I never did the valves correctly. I had them to tight on the odd side. Now that she is all back together she starts right up and runs great.
thanks guys
