jim daigle
Thread starter- Joined
- Nov 26, 2007
- 22
I just picked this beast up, its got good compresion and will eventualy make a great motor I just need a little more knowledge on its proper operating procedures.. I have 2 two oil resivours one mounted on engine and one seperate, all relative cables ie wiring harness's I tried cranking it with key on bench and it will only alarm out on what I assume is the oil level in tank mounted on engine. The starter dose crank the engine when i jump the solinoid thats how i know there is good compression am i missing anything here or do i need to digg deeper into the wiring here? Is there a fault mechanism that trips out the start circut when alarming? Oil tank on engine is empty and tank in boat is half full and pumping oil...jim d USA model ETXG
