1989 Yamaha 30 F 2 stroke, 3 cylinder Pilot hole is dry??? Please help advise
hslobo
1989 Yamaha 30 F 2 stroke, 3 cylinder Pilot hole shows no water flow. Overheat alarm triggering, I put the muffs on and had a look.......very limited flow out of drainage holes on lower unit, no flow out of pilot hole when throttle is engaged. Is there anything I can do to check for blockages or clogs before having to remove the lower unit. Ive never done that before and want to avoid it if I can. Please....any and all suggestions are appreciated.
CheckmateEnticer
Re: 1989 Yamaha 30 F 2 stroke, 3 cylinder Pilot hole is dry??? Please help advise
Not sure but lowering the lower unit is no big deal and something every boater should be familiar with in my opinion.
99yam40
when was the water pump and stat replace last?
