Powdershredder
Thread starter- Joined
- Sep 12, 2018
- 30
Looking for a few ideas as to why I may be having water intrusion on cylinder 3 on my rebuilt Yamaha PRO 50LF. Compression test reads 120 at all 3 cylinders and all 3 cylinders have good strong spark.
The motor will start and run fine until it kicks into low idle at which point it begins to mis and sputter. The motor is consuming a large amount of fuel and there is a large amount of fuel coming through the exhaust, which I assume is being expelled from cylinder 3 un burnt due to no ignition as a result of what I think is a water intrusion issue.
The plugs have have been pulled and examined cylinder 3 is wet and clean as is the piston itself, as if they are being washed clean. Cylinders 1 and 2 are firing with no issues and have a nice even noticeably darker color from cylinder 3.
Any ideas?
Any ideas?
