I will change my plan for the bilge, everyone is offering the same advice so I know it was a bad ideaDefinitely direct wire the bilge pump with a separate float switch. I have mine wired up to a helm switch but nothing should be wired to your starting other than the motor and it's trim.
That's a ton of good info, thank you!I’m late to the party too.
Sorry for the goofy spacing. I copied to notes and added later as it was a work in progress.
And it’s long winded.
My advice as an electrician and contractor.
Don’t ever skimp on wire size.
Smoking cables and over amp draw is not something you want and especially on the water.
IFFFF… all powers that BE forbid…,
Should you actually have a fire,. On the water you have nowhere to go but in the water should the need ever arise and you can’t get control of things.
Bear in mind you could have cold water or if you are in the ocean other problems to deal with. …
So far as those big cables matching?
Yes they need to match, just like on a car and in the house.
And speaking of houses, the smallest wire we pull is #14. It doesn’t matter if the entire circuit is feeding a single LED. OR no load at all.
My point is, don’t try and size things for a small 5 or 10amp load,
If it were me, I would follow the #14 thing, and fuse accordingly.
But I know there are 16 and 18 gauge ran for small loads ran for DC.
AND yes It’s easier to bend and flow the contours of small wires and just easier to work with. I get all that too.
But pinching pennies on smaller wire when you could just run 1 smallest size and not buy 1/2 dozen 25-50 foot rolls.
You could buy 250’ roll of black, red, blue, white or green or any other colors you choose.
Then use the money you saved not buying the little $chit and throw that money on the few bigger sizes that you will need.
Wire in bulk or big rolls is way cheaper in the long run than hand fulls of little packages is the point I was trying to make.
And running 10’ feet and 2 wires at a time can eat wire quickly is another thought.
Back to the big wire question,
You at some point carry a return or sometimes we call it an unbalanced load.
Whatever current or amperage that travels on the Hot wire has to return somewhere…
It doesn’t just disappear or dissipate into thin air like the magic smoke you try and get back into a burned up motor or capacitor.
Wire is way cheaper than a fire or an afterthought or underthought or underthunked.., an install that turns into a repair.
I’m not trying to tell you how to do your project, I’m just pointing out the ins and outs you could be overlooking at saving a dime and the better “maybe” safer way to do something.
1 other thing.
If you run bigger wire and you later add something that requires a bigger cable you are already good to go and no additional circuitry to add or upgrade.
Hopefully I was able to help.
Good luck
To keep solid connections make sure you use terminal blocks with a separate connector for each wire lead so you don't end up stacking connections. I like these.I will change my plan for the bilge, everyone is offering the same advice so I know it was a bad ideaI don't have a lot of accessories that will take much power, and tons of boats only have one battery, so I wasn't too worried about having everything but the trolling motor hooked to the start battery. Time will tell I guess!
Thanks, I picked up a litre of the heavy duty Resolve to try out before I commit to a gallon for $76Sorry, bad memory... Solvable brand. I bought a couple jugs at the ReStore where they clear out Home Depot returns. There is regular and 'heavy duty'. The heavy duty was what I ended up using and had good luck with. Cdn Tire sells it as well, and it doesn't get very good reviews, so YMMV. Get the smallest container and give it a try first. If you have a ReStore, check there also, as they had lots of the Solvable brand thinners, MEK, acetone, strippers etc last time I wandered through. Maybe it's the same in your area?
General PDP Template
www.canadiantire.ca
Yup that’s it. I used a flexible metal putty knife to scrape it off after it soaked a few minutes
Thanks! I'll pick some up tomorrow.Yup that’s it. I used a flexible metal putty knife to scrape it off after it soaked a few minutes
I used a little less than 2 quarts to do my ss16 to give you an idea how much you might need.Thanks! I'll pick some up tomorrow.![]()
Thanks, but I don't think that is available anywhere in Canada, I couldn't find a good source.Don't mess with the red SC smeg other than to remove any loose bits around the edges if there are any. Yeah apply the Gluvit over it if need be.
The only thing that took the carpet glue off my SS was Klean Strip adhesive remover and a pressure washer.
Port cleaned, starboard you can see what I started with.
I also found about 6 spots where someone drilled the floor screws right through the rib ends and then the bottom hull, then covered it up with a very well adhered rubbery substance on the outside. Those spots will all get sold rivets once once the paint is stripped.
