sloopjohnb
Thread starter- Joined
- Jul 17, 2006
- 10
my batter was not charging, at idle I check the battery votage... 12V
checked the voltage the disconnected the red wire leaving the voltage regulator (in hind site after reading some other posts I'm not sure if this was a good idea) and left the internal one connected). restarted the motor at idle and checked the voltage on the red terminal .. 4V
checked the voltage on the yellow (stator) wires 20VAC
reved the the engine to about 2K and check the voltage on the yellow (about 30-50 vac), checked the output on the red terminal 14.3 V.
not sure if this this indicates the regulator/rectifier is bad or should I be looking at something else?
any advice?
any advice?
