nwboater45
Thread starter- Joined
- Sep 6, 2012
- 91
I am new this motor and still trying to dial it in. One issue was fuel and will need to drain the tank. Anyways the questions I have while doing a link and sync are:
1. What is the best way to ground the plug wires? Anyone have any good diagrams or photos? A really good description will also help.
2. I am assuming that the timing light is still connected to the #1 plug wire....correct? The service manual calls for the light to be connected to the block.
3. When it is all said and done what is the typical idle RMP's in neutral while the motor is in the water tank? I know it is suppose to be 650 while in gear but I can't run it in the barrel in gear for very long. I want to get it to a good point then adjust it on the lake.
Thanks.
Thanks.
