1990 140hp johnson fuel pressure?
vip-vindicator
looking to know how much psi does the stock fuel pump make? how much psi can the carbs take before over comming the floats?
Thanks
tashasdaddy
Re: 1990 140hp johnson fuel pressure?
sounds like you are planning and electric pump, DON"T. extreme fire hazard, outboards are not designed for them.
vip-vindicator
no my pump makes 6psi and carbs have been cleaned an rebuilt new filter also . the problem is while running all 4 carbs dont stop the fuel ( over fills) only work at wot.
reeldutch
the only thing that wil stop the fuel pump dumping fuel in the float bowls is the needle and seat.
i would replace them if they leak.
what color is your pulse limiter?
