Alpinegold
- Joined
- Mar 8, 2007
- 99
I really need some guidance on my issue. Bought a 1989 Nitro 19' with a 1990 150 Johnson GT. The motor bogs down on hole shot and will not plane up. Originally had a 4 blade shooter prop 25" pitch and replaced with a 3 blade prop with a 21" pitch. The boat also has a jack plate which is fixed and can't adjust it while on the lake. When I first bought the boat in October 2013 the boat would plane up but noticed the bow would come up rather high when planing although I was trimed down on my motor. ( Prior to the nitro I had a v178 Ranger with a Johnson 115 motor and it would come out of the hole like immediately. ) When coming out of the hole the motor sounds bogged down and now it will not plane up at all? A friend of mine tells me he thinks it could be a leak in my manifold gaskets. I have a Johnson service manual and going through it the cause of power loss could be a ton of things that I'm not technically competent on 99% of.
Also having live well issues which is resulting in a lot of water going into bottom of boat even though I repaired hole in recirculating hose and cant identify where all the water is coming from. If anyone knows the livewell system Nitro was using back in those days I sure would like to talk to you regarding this subject.
Really could use some advise as I have already spent over $ 1000 on new water pump, aerator pump and timer switch and leaking vro pump. Vro was disconnected prior to me buying it.
Alpinegold - I'm really pulling hair and teeth at this point.
