1990 2 bbl Mercarb choke
CHARGER2
My 2 bbl mercarb choke is not opening all the way when underway at full throttle. Is there a diagram that shows how the linkages are supposed to be? I am under the impression the throttle linkage is supposed to force the choke open no matter the engine temp when wide open. Is this right? I am looking for a "linkage map" of how this looks at WOT.
Thanks for any help.
Don S
Re: 1990 2 bbl Mercarb choke
The throttle linkage only opens the choke a small amount, and the vacuum break opens it a little further. If it's staying closed, either the choke coil isn't working or it's adjusted way too tight.
What engine is this on?
