1990 25 johnson stall at high speed?????
985johnm
the motor was stalling out at high speeds and it just kept getting worse and worse till it was hard to idle. I put new plugs in it and rebuilt the carb. I still have the problem, it got a little better after the rebuild though. any suggestions?
steelespike
Re: 1990 25 johnson stall at high speed?????
Does squeezing the primer bulb help?
985johnm
yes, it will just about run normal !!!!! what is it?
bktheking
Fuel pump is weak perhaps, squeezing the bulb is feeding the carb. Is the fuel tank venting properly?
2 things to look at
985johnm
the tank is vented properly. I suspected the fuel pump. Is there a fuel pump exploded view anywhere? Do I have to rebuild it or clean it?
bktheking
First check the filter, remove the screw where it is written filter on the pump and check it. Check your lines to make sure they are in good condition and there is no crap in them. Shop2.evinrude.com will show you the exploded view of the pump, there is an early and late production fuel pump. If the pump is bad there are kits to rebuild them, they are a pain to rebuild or you could just replace it.
blksmith1
I have the Evinrude version. I rebuilt my pump without much luck. Bought a new one and am running strong again. Check price on iboats. much better than most.
Take care
TJ
